BOBINA ACCEL SECA MODELO 140025 100% MADE IN USA
NUEVA , EN SU EMBALAJE ORIGINAL , KIT COMPLETO TAL CUAL LA FOTO .
LA MAS POTENTE DE ACCEL !!!!!
MODELO SWITCHABLE , DOS POTENCIAS DISTINTAS , DISEÑADA ESPECIFICAMENTE PARA AUTOS DE CALLE Y PICADAS.
ESTE SISTEMA PERMITE EN EL MODO STREET (CALLE) TENER MAYOR CORRIENTE Y MENOR VOLTAJE PARA ECONOMIZAR COMBUSTIBLE Y TENER MEJOR RESPUESTA EN BAJAS E INTERMEDIAS RPM , Y EN MODO RACE TIENE MAS VOLTAJE Y UN POCO MENOS DE AMPERAJE PARA LOGRAR EL MAXIMO RENDIMIENTO A ALTAS RPM , SE ACTIVA POR MEDIO DE UNA TECLA .
TAMBIEN SE PUEDE UTILIZAR EN MODO RACE PERMANENTE SIN PROBLEMAS .
EL KIT ORIGINAL INCLUYE:
BOBINA , CABLEADO , TECLA TIPO AVION Y RELLAY ESPECIAL ESTANCO IMPERMEABLE , TODO ORIGINAL ACCEL
PARA MAS INFORMACION CONSULTE POR NUMERO DE PARTE EN LA PAGINA DE ACCEL .
DATOS TECNICOS
Brand ACCEL
Manufacturer's Part Number 140025
Part Type Ignition Coils
Product Line ACCEL Afterburner Switchable Coils
Summit Racing Part Number ACC-140025
UPC 743047821282
Coil Wire Attachment HEI in-cap
Coil Style In-cap
Coil Internal Construction Epoxy
Coil Color Black
Mounting Bracket Included Yes
Coil Wire Included No
Ballast Resistor Included No
Switch 1 55000 V 420 MA
Switch 2 70000 V 360 MA
SENCILLA INSTALACION YA QUE EL CABLEADO ORIGINAL VIENE LISTO PARA INSTALAR
SE PUEDE UTILIZAR CON ENCENDIDOS ELECTRONICOS ORIGINALES DE FABRICA ASI COMO TAMBIEN CON ENCENDIDOS MULTICHISPA MSD Ò FS .
700 pesos
Para mis datos o contacto enviar MP
